I replaced the impeller this morning and after re-installing the lower housing. Was able to slide the cable from the motor in and out by hand. ( No binding ) Shifts fine into forward, but wont engage reverse. While out of gear theres at the back of the boat I can hear a knocking sound from the gear housing. In forward gear this sound goes away. I followed instruction on the gear linkage on the lower housing being turned clockwise, and the control in forward gear. Should I start over or is this something other than the linkage?
