shift problem forward to reverse
karayj
ok heres one I have a 18 ft 1986 sea sprite 205 hp v6 4.3 alpha 1 <br />when i shift from forward to reverse with the engine off it a smooth process when I start off from the ramp with engine on from netrual to reverse then into forward its fine but later in the day comming back when I'm in forward gear and go into reverse to slow down to make adjustments at the ramp it sticks hard sometimes I have to shut off the motor put it in netual start it back up the go to reverse or pull on the lever to the point I feel I'm going to break the shifter.<br />I have adjusted the cable seems to help but very little then the next trip out it happens again ita real problem at the dock what can i do? Alos I have adjusted the idle to 800 that helped a bit more do I need a new ****er? again when the motor is off its fine thats the key i think. uniflex ****er the plasic guide inside is worn a bit could that be it but why does it shift fine with the motor off here is a pic of the guide its not mine but it looks like this any one have a spare or a ultraflex shift for sale ?http://ebay0.ipixmedia.com/abc/M28/_EBAY_335de034d1768a9be4ed3175f268cba8/i-5.JPG
Re: shift problem forward to reverse
Your lower shift cable is Shot.... Replace it,+ your problems will go away....
karayj
Thanks bondo I have already replaced it I talk to someone that sells my type of control he said its the switch on the throttle/shift control unit that sits on the engine .....
record hunter
Do you have a netural safety kill switch that thing has to be adjusted just right I had a simular problem and that was my problem. I actually just adjusted it and works When you shift between forward and reverse that switch kills the motor for just a second so you can shint. I had someone tell me once I did not need it so I disconected it and my shifting was just like yours so you need it and it has to be working right Good luck
