My Cobra shifts smoothly into forward and runs fine. However, when I shift it into reverse it seems to bog as the gear engages, then stalls when I apply throttle. When I disengage the drive (by pushing the center button on the shift lever) the engine throttles smoothly in both forward and reverse directions. Was wondering if anyone had any ideas? I was thinking it might be a shift interrupter switch problem where it doesn't disengage and return the engine to normal unretarded operation once in reverse...any thoughts?
Took the boat to the shop and mechanic said he adjusted the shift cable and now the boat runs like new...however, when I put the boat in the water it exhibited the same symptoms with exception of a couple of times that the engine did not stall (those times I shifted into reverse just enough to engage the drive then let it idle back, then slowly applied a little throttle and the engine didn't stall...amazing).
Getting frustrated and hope someone can tell me something I can tell the mechanic to put him on the right track.
