Re: Shift problem
If nothing has been disturbed, your lower shift cable is sticky from the non-use.<br /><br />Disconnect it at the shift plate and cycle it end to end. If still no good, try WD40 at the drive end. Still no good, pull the cable out, clean and give a coat of WD40. Do not use grease.<br /><br />If cable is rusty, change it, cleaning is no good.<br /><br />Good luck.<br /><br />Qystan
