shift rod 66 18h evin. fastwin
J Headrick
when in neutral, the prop should beable to be turn by hand freely right? when in forward ar reverse, the prop shouldn't beable to spin freely because it is engaged right? if this is the case, then is this normal that somtimes when i shift into F or R the lever doesn't seat fully in the rests, if i turn the prop a bit then it pops into place. :confused:
J Headrick
Re: shift rod 66 18h evin. fastwin
the manual just says you should check to see if the gears engage correctly, well what is the correct way. just wondering if any had any personal exp. thanks ;)
alcan
Hi Headrick<br /> Yep, sounds healthy. It requires a partial revelution for the cogs on the shift dog to engage the gear unless they happen to be lined up to start with. This is normal.
J Headrick
now i can breathe a little better. i'll let ya all know how she runs after monday. after all the work i have done in the last few days i hope she runs well. :cool:
Chinewalker
Most manuals also say not to shift the motor while it isn't running, as you can jam the shift clutch into the gears...<br />- Scott
micar
is there any way of getting the gearbox outof gear when this happens? I did it to my '84 35 evinrude and had to get a another complete gearbox for it.....
