No Title
Update,
I have the bellows type lower (that is why I had to do this, the bellows broke allowing water into the lower, could not find another plate).
I had another gear case top plate fabricated to accept the normal type shift rod seal (Franz Marine). Apparently I have an 89 power head and a 90/91 lower unit.
I tried screwing the rod all the way down, no go. Would not go into forward. 4 turns out, still not enough. So, I split the difference.
Screwed it back down to 2 turns out, adjusted the two nuts upward, and a slight adjustment to the remote shift cable. I think I got it now???
I can run thru F-N-R and the prop does what it's supposed to do.
Yes, this was rather tedious, especially not having done it before.
Others? Be sure to disconnect the battery first, had sparks flying. Had to remove the air intake, and use a short 1/2" wrench on the rod nuts.
