Oldsaltydog
- Joined
- Jan 27, 2004
- 322
The motor is a 1998 Force Mercury 90HP. After rebuilding the water pump, as I was reistalling the lower unit, I must have done something wrong, because the splined shifting rod was pushed in and became disconneceted inside the gearcase, and now it flops around without doing any shifting, in fact, it can be pulled straight out. Looking at the diagrams, looks like the shift rod and the shift rod CAM became separated. How would you deal with this problem, besides taking the whole LU apart, or is that the only way? Should I order a new shift cam first? Please help.
