Re: Shift rod disconnect
The cables are in the way, making it difficult to reach the bellcrank screw, which is about midway on the two parallel arms which connect to the shift rod.
At the end of the two arms is a pin which goes through the top swivel of the shift rod.
The bellcrank screw must be removed and the arms spread to release the rod.
With the motor tilted up you will find two bolts on either side of the gearcase, facing up. There also is one in front of the trim tab, and another hidden above the trim tab, which must be removed first in order to reach it.
Including the trim tab bolt, that is a total of 7 bolts to remove from the gearcase - all facing up.
Be sure to mark the location of the trim tab before removing it so that you can put it back the way it was.
Try not to turn the swivel on the shift rod.
