while replacing water pump i must have moved the shift rod and it is not positioned in sync with the boat shift lever. (i.e. neutral on boat shift lever is not netural on motor). To synchronize is as simple as rotate shift rod to neutral and then reconnect to the split bolt linkage with lever in neutral. also when muffs are connected should upper pee stream hole at back of motor housing develop water. water comes out holes on lower unit but none at back of motor. also water coming from seam at top of lower unit seal. Is this a pump seal problem?
