Shift rod measurement WRONG
jpendergrass
Removed the LU to measure the shift rod height and replaced waterpump while there(glad I did). 1976 Johnson 135hp spec is 21 13/32". Adjusted length and reinstalled LU. When going up(reverse) the rod hits the block and cant go any further which in turn does not allow reverse to happen. I would guess the room needed would be around a 1/2". I dont believe the LU is the original, so how do I find out the year so I can adjust this once and for all?????
jpendergrass
Re: Shift rod measurement WRONG
By the way, the only # i could find stamped on LU is 716M
