Re: shift rod removial 150hp evinrude
If it is Quick stab type remove cotter pin from easier to get to linkage arm and its pin .Arm can then be pulled back disengaging shift rod.Probably easier to see shift rod after intake boxes are removed.I had to pull starter on mine so i could easily see to re-align on reassembly.That and a few choice words should get it.Better design if it is quick release,Yet still hard to get to.If it is not quick connect type you'll have to remove small pin bolt from shift rod end.
