Hey guys, I have a 1963 40hp evinrude long shaft. It's been sittin awhile. I dropped the lower unit to service the water pump. The shift lever seemed stuck before I pulled the lower unit. Problem seems to be the shift rod is fozen where it enters the gear case housing, shift lever works fine at power head. Is this a split or single housing gear case? I'm trying to determine how best to free the shift rod. Trying to get a blow up of the gear case from the manual before I open it up but don't know which diagram to use. Also, any tips of freeing stuubborn screws on the gear case would be helpful.
Thanks for any help.
Keith:$
Keith:$
