Johnson. 40. 2 STk. (2004) where do you disconnect it when removing the lower end?
T tav Petty Officer 1st Class Joined Feb 8, 2008 Messages 239 Mar 7, 2014 #1 Johnson. 40. 2 STk. (2004) where do you disconnect it when removing the lower end?
J James R Commander Joined Feb 1, 2007 Messages 2,679 Mar 7, 2014 #2 Re: shift rod The shift linkage is located under the carb. There is a screw that goes through the linkage and the shift rod. Difficult to see but look under the carb from the port side and you should see it.
T tav Petty Officer 1st Class Joined Feb 8, 2008 Messages 239 Mar 7, 2014 #3 Re: shift rod i'm at work now ....but do i have to remove front cover to get at it? should it be in forword or rev when removing it? Last edited: Mar 7, 2014
