While replacing my impeller, I thought I would dislodge my speedo passage by blowing compressed air thru quick connect located near impeller. I could not get the passage way cleared so I pulled the shift Shaft 815919A1 and when I pulled the shaft up I heard a distinct click. I got the passage way cleared out and when I wen to reinstall the shift shaft it does not go all the way down into place, with about 3/8" gap between housing and shaft holder. I shined a light down in the hole and there seems to be a pin lying in the bottom of the shift shaft hole that is probably the reason the shaft is not seating. What do I need to do to get this pin back to it's proper location so I can reinstall my shift shaft that will allow it to be seated correctly? I have search the forum but did not find anyone with this shift shaft problem that posted up their solution to this problem I am encountering. Thanks in advance to anyone who can help resolve my issue, alorio1......
This is an Alpha 1 gen 2 outdrive number 0D797230
