i got a 1971 chrysler 35 hp.i found a chrysler shifter/throttle control for it finally.but i have the same problems that i had with other controls.they work backwards.my outboard was missing the remote unit so i,m going blind.my manual shows the linkage to the carb ,and the forward/reverse lever,but i dont a have a picture of the actual cables hooking to the levers.i'm sure i missing something,but not sure what piece.<br /> what i mean by working backwards is if i run the cables through the front of cowl( only cut out available)(carborator end) the cables want to push the levers,i need them to pull.i tryed a johnson and mercury control withe the same results.if i run the cables around the power head and come from behind(the cylnder head end)they would work but there is no bracket to secure cables.so whats missing?<br /><br />also the cable ends just have threads,i need somekind of crimp end.
