IslanderVT
- Joined
- Mar 13, 2013
- 48
'88 Mercrusier 260HP Alpha 1 with standard Quicksilver Commander shifter assembly, all original.
Button on top of throttle, which interlocks the shifter from moving into gear unless its pressed, seems to be stuck in. The button itself isn't stuck...it pushes in and springs back like normal. But it has no effect on shifting.
It will move into either forward or reverse without pushing the button. Otherwise everything seems to work fine. Throttle-only button works properly. Shifts into forward/reverse smooth, no problems. No issues with the shifting interrupt switch back on the engine. Cables seem to be fine.
Just doesn't have the stop in neutral that my wife and I are used to, so its real easy to slam it from reverse into forward...no click & stop at neutral.
Seems like I've heard of this fail mode before...is it a common problem?
Any thoughts for the best fix?
Have not taken it apart yet...hoping for some wisdom first!
Thanks!
Thanks!
