Hi All;
So I got the engine alinged, (Thanks for all the help with that)outdrive installed, and cables hooked up. I'm haveing a little problem with the shifting, here is the situation;
I start the engine by depressing the throttle button to disengauge the quadrent, give it a couple of pumps, set the throttle between neutral and full forward, and start it up. runs great.
When I proceeed to bring the throttle back to the neutral position, the throttle button snaps out, and the engine dies.
I followed the manual in adjusting the cables for shifting, everything is hooked up and tightened.
Wondering if anyone had any ideas, as to what is the cause and fix.
Thanks for any help
Cheers
Tom
Thanks for any help
Cheers
Tom
