MASTER Brian
- Joined
- Mar 26, 2006
- 738
My 86 Ranger sat for last year and half because I needed to replace the midshaft exhaust gasket. I finally completed that and the boat wasn't idling well, so I ran out to a marine shop at the lake....5hrs away. Don't trust local shop anymore and this one is by my cabin.
He checked everything and got the boat to fire right up and idle nicely, BUT in doing so the prop started spinning while in neutral at higher rpms. He went ahead and adjusted the lower linkage on my E-XP 150. The boat stopped the grinding sound that was slightly there when going into gear and ago seemed well until......
I left and headed to the water a while later. I put the boat in, she fired right up, idled as well as she has in long time and went right into reverse with no issue, but when I tried to go into forward, the motor just revved. I backed up to the courtesy dock, pulled the cover and noticed, he forgot tutti screw the clamp for cable, didn't seem to move as was still in position. I secured the clamp and with boat off I checked the prop to see when it locked prop in. Both reverse and forward seemed to be more into the throttle position than I recall and the motor revs a bunch before out snaps into gear. More so in forward than reverse.
He mentioned maybe adjusting the idle cam? if it idled too high or low when in water, but idle seems great. He also mentioned the shift dog might be wearing out, but after he was happy with play on land, he seemed to say maybe just replace the cable and the controls at some point as neither are real expensive and those cables stretch over time.
I don't recall this ever before, but it did seem to clunk into gear, nothing bad, just a quick clunk sound, which I've heard on many older outboards.
I'm wondering if a cable might be answer, if that shift dog is bad and how difficult if job that is. I'm also curious if the throttle cable might have gotten out of whack when I pulled PH to replace the gasket. I wss careful, but can't rule out a slight turn of the adjuster, apparently the shift adjust got moved a little.
It seems like instead of going forward right out of idle, 800-1000rpms, it takes until about 2000rpms to engage the prop.
Where would one start ? I would have stopped back, but it was the next morning when we got out and he said he wouldn't be in long that day. He did the other repairs while I waited the day before and I think he was just in shop finishing some stuff up on a slow day.
