I was putting up to a dock when the boat in front of me decided to change docks and put it in reverse. I shifted real fast while moving forward into reverse. There was a grind then I lost reverse. It would rev, but not go anywhere. I still had Forward and got it back to the dock. After I pulled the boat out I played around with the controls and tried to spin the prop by hand. When the contols were in the Netural position the LU was in gear. When the controls were in the Reverse position the LU was in Netural.
Today I took a closer look at:
The controls seem to have good travel with the cables and I do not think they are the problem. I disconnected the inner cable and tried shifting by hand with the motor NOT RUNNING. With the shift lever Straight up and Down the motor appears to be in N and the prop spins freely. When I push the lever F towards the boat the prop still spins freely and acts like it is in N. When I push the lever rearward it appears to go into gear but pops right out when I spin the prop with my foot and then it feels as if a internal shaft is spinning.
Looking at it today looks oppisite of what I saw at the ramp when I pulled the boat out. The cold test tells me I have no forward gear and reverse will not stay in gear. Is this correct? All of my experience is automotive so any advice on how to dianose this properly will be greatly appreciated. What should I check first?
