Shifting Woes
marksa1458
Have a 1968 Mercury 500 s/n 2479530 short shaft. The problem is it would stay in forward gear - dropped the lower unit, realigned the gear shaft splines bolted everything back up - Forward/Neutral/Reverse all works great. Tilt the engine up shift forward, shift back to neutral and reverse and bam the lower unit will not shift out of forward anymore.
The linkage at the powerhead looks ok, movement is good, adjustments look right. I am thinking there is a problem in the upper shift shaft slipping somewhere. My question is - is there a common place where these shafts can slip and how difficult is it to replace with a new shaft.
Also, anyone have an idea where I can find a good shift shaft?
Thanks,
marksa1458
Re: Shifting Woes
In looking into further - there is a threaded rod that has a coupler attached to. The coupler was locked in place by a set screw that was badly corroded.
This doesn't look like the original factory design:
and here is the coupler with the set screw
Is this the original design? there doesn't appear to be any threads in the coupler..
