shiftingrod
dpage
1988force1251x8aoutboardhowdoigettotheshiftrodtoreplacetolditwasbroken
foodfisher
Re: shiftingrod
Topisvisableunderthecowling.Midleghasacoupling,alsovisable.Whereisthebreak?
92rslt1
Re: shiftingrod
it should unthread from the lower unit.
dpage
Re: shiftingrod
do i have to take motor apart. i know cars inside and out but nothing about outboards. thanks dave
92rslt1
Re: shiftingrod
if your talking about the actual rod, you have to take off the lower unit.its like 8 bolts. might as well order a water pump kit too and change your gear oil. you have to take the water pump off, its easier to replace with it off. good time for a little maintenance.
john from md
Re: shiftingrod
Replacing the shift rod will require removing the guts of the lower end. If you haven't bought a Clymer Force Outboard Shop Manual, you need to before starting this job.
John
92rslt1
Re: shiftingrod
My force shift rod un-threaded from the lower end. Unless we are talking about an internal shift shaft of some sort. the rod im referring to runs through the water pump base and threads into the linkage in the lower end. no dissection needed except the water pump and base.
