Johnson 150,88 model#J150TLCDC, last fall, pulled the lower unit to replace the water pump, re-installed lower unit yesterday, and now it wont shift either to forward or reverse. Droped the lower unit back out, my question is this, should you be able to move the shift lever while turning the drive shaft, and if so, how much effort to move said shifter. Was working great before. All seems to be fine as far as the cables and throttle housing. I put some pressure on the shift lever to try to get it to move up or down but not sure how much pressure it takes. Help please.
Eddited to add, replaced the gear oil while the unit was removed, no water in the old oil.
