Nickypoo
- Joined
- Mar 21, 2012
- 287
Hello everyone, I'm in the middle of reconditioning my 270 outdrive off my AQ125a setup due to bad watertube seals. I pulled it apart, sandblasted it, painted it, and now finally reassembling it with new seals.
The lower gears were fairly straightforward. I reused the old shims and then checked the gear mesh pattern with a permanent marker. The mesh pattern looks like that from the service manual.
Now I've come to the upper gear unit. This unit is way more complex, and I realized that I don't currently have the capability to do it correctly. I mixed up some of the shims so now I'm a little lost.
I thought I might just have a professional shim it, but as usual it seems like to get a pro to do something on this boat is like pulling teeth. I called the local Volvo Penta service specialists to get an estimate for them to do it. The person I was talking to asked what the condition the rest of the drive is in, if I've pressure tested it, etc. I said the water tube wasn't sucking up water, so I took it apart and decided to paint everything and replace all the seals while I was at it. They say, in a condescending tone I might add, "Well, the water tube doesn't suck up water". The water tube doesn't suck up water!
I just said, well yes it does, if the seals are bad then the impeller can't pump water. They took my email and are going to get back to me
So now I'm back to considering tackling it myself. My questions are below:
Thanks in advance.
- I'm thinking about buying digital calipers and using a depth base instead of a depth micrometer. Would this be sufficient for the job? I'm thinking about future use. If I buy the calipers I will use them many more times. The base micrometer will be used once.
- How much should it cost to have a pro do the shimming? I was thinking if it was around $50-$70 then it may be worth it.
Thanks in advance.
