I'm replacing the head gaskets on my old '76 Johnson v4 85hp due to a water leat to the outside. Now that I am looking at the cylinders, one has a small scuffed looking spot. I can't feel anything with my fingernail. It almost look like the oil is scuffed off showing clean metal, but its not. The engine runs perfect and compression is fine. Should I worry or is it ok? Also, is there any danger in cleaning the pistons/heads with some seafoam spray before re-assembly?<br /><br />
