Shipwrecked
floattest
I've been boating with my 79 Formula for three years now. It's going to hurt to post this story of me screwing up but maybe it will help someone else.
It's an old boat and an OMC so each season has required some rework or repairs. Got through all that and this season had to replace the distributor becasue it was self destructing inside. Now have a new Mallory breakerless and a new shift module and the boat runs great.
Lesson one. Keep your boat running good, it will save you later.
So my friend and I go out on December 4th on Puget Sound out of Everett. Perfect day, stayed warm in the boat. It was about 30 degrees at launch. Got up to a balmy 38 later in the day. Pulled up 6 dungeness. Perfect day.
About 3:30 we started back to the east and to the north for the 10 mile ride back to the launch.
We decide to go straight east and take a look at a spot called shipwreck on the west shore between mukilteo and edmonds. There is a big ship up on the beach and I have never really taken a look at it.
Lesson two. Stay on mission, this was a crabbing trip.
Well we putted around the general area and I was carefully watching the depth sounder and we never got in less that 9 feet of water. I thought we were safe at about 60 yards off the beach and in 9 feet of water. We turned to the north and were runnning at about 7 mph when we hit something and the boat stopped hard. Real hard, an instant stop. Hit my face on my steering wheel, bloody nose. My buddy got slammed into the dash on his side, bruised up a bit.
I turned the boat off immediatley and lifted the drive to take a look. I figured that the outdrive hit something. Nothing, no damage, not even a ding on the prop.
At this point we had to assume that there was some hull damage. Turned on the bilge pump and we were pumping water. Got the boat started and under way and made out at a fast pace to get her out of the water asap. This is where the work on the engine paid off. 40 minute boat ride, mostly at about 30 mph but the the slow ride into the channel. The engine works perfectly now, will idle as long as I let it, will start every time. And has never stalled since I replaced the dizzy. She got us all the way back to the launch and the front of the boat was starting to ride a little low so we knew were taking on a good amount of water.
Well after getting it out of the water I found a straight slice out of the keel at the bottom of the stem about 3 inches by 8 inches. A good size hole for the water to come in. It drained water out of this hole for about 15 minutes.
After investigating using google earth it turns out this area used to be a slavage yard and there are lots of wrecks there. You can find pics of the area on the internet. One of the wrecks, the one I hit, is out in the water a good long ways, 40 to 60 yards. And it is visible at low tide. We were out at nearly the peak of the tide, +11 feet. This wreck was not visible at this time and I didn't know it was there.
Lesson three. Know your waters. If you are in unfamiliar water give yourself extra margin for error. I'm going to stick to 20 feet more of water unless I know the area.
Also the chart shows a shipwreck symbol there but I always thought that symbol was for the boat that is on the beach. Now I know better.
All told, it could have been much worse. It hurt the captain's pride a bit, but the fiberglass is fixable and nobody got seriously hurt.
Have fun out there and be safe.
FT
tx1961whaler
Re: Shipwrecked
Are those little white speck pieces of your boat ?? :D:D
Glad it turned out OK. Could have been much worse, although you could have pointed it toward shore and beached it if it got too bad. Too darn cold to be swimming....
floattest
Re: Shipwrecked
Whaler, thanks for putting that picture up. Yep, that's the spot. It doesn't seem possible that one could miss it, but like I said the tide was high and none of it was visible.
Next time I go out (next spring) I want to go out at low tide and take a look at that area (from a distance) and see what it looks like.
I really thought I hit something that was not marked or that wasn't charted. When I saw that picture and verified the spot against my GPS I felt like S#*T. How could I have been so stupid as to get that close to that area. NO REASON. Just dumb.
pscrabber59
Re: Shipwrecked
FT, now you know why that area is called "Shipwreck". A friend's father ran aground years back there, he got messed up a bit but the boat was destroyed and i think it still might be there?? Anyway at least you guys got some dungies!!
floattest
Re: Shipwrecked
Pscrabber, Oh, I could see how that wreck could destroy a hull easily. We were going real slow, just over idle, I figured about 7 mph and it put a big hole in the keel. Luckily we struck the wreck, probably a big chunk of rusty steel, dead on the keel at the bottom of the stem, a strong spot on the hull. If that obstruction was off center a little or we were going faster, it could open up a boat like a can of tuna.
Like I said, lesson learned, know your waters.
Easy to say but if you have ever looked at a map of puget sound you'll know it's almost impossible to know all that water, and of course the tides change everything.
I always figured high tide is better, but didn't consioder that high tide could hide an obstruction that is otherwise visible.
Tricky waters. I'll keep at it, reading the charts, and reading as much as I can.
I use google earth a lot for general purpose but was lately using it to site out the shoreline along the water I navigate. It's quite amazing what you can see and along with that the cursor shows the gps coordinates. I figure it's worth making notes on charts or even putting in markers in the gps to watch out for.
Happy Holidays iboatnuts.
BoatingCop
Re: Shipwrecked
Thanks for posting. An eye opening story for sure. Just glad you weren't seriously hust and the boat can be fixed. Did you get any pics of the damage and have you gotten around to repairing it yet? Glad you're ok.
5150abf
Re: Shipwrecked
We were out on the river once, it was night so I was only going 4-5 mph about 30' off an island in 6-8' of water.
All of a sudden the bow starts to rise and the boat stops, no sounds, the bow just raised up 3'.
So I am looking at my buddy and he is looking at me waiting to see what happens next, I finally get up to look and see what we hit when the boat starts to roll to port, tackle box hits the floor I am sure it is the end and we are going swimming adn I am going to sink my boat.
It stops rolling, I check the transom and we aren't taking water so everything is okay and I finish my climb to the bow expecting to see a log just under water, even with a million power spot I can't see anything just the bow 3' in the air in 8' of water for no apparent reason.
We are in 6'-8' of water so getting out to push off is out of the question so the only hting I can think to do is start the engine and put it in reverse and work the steering back and forth.
After a couple minutes of that we slide back off of whatever it is was, idle up to look and it turns out I hit a stump 8'' across dead center on the keel, 2''-3'' either way and we would have just slid off, ti was by far the wierdest thing that I come across in a boat.
No damage, I can't imagine being 40 minutes from the launch taking on water, that had to raise your blood pressure a bit.
Glad it worked out for you.
Home Cookin'
Re: Shipwrecked
I've had that mysterious bow rise occur twice-once it was a piece of a house and once a piece of a wrecked boat. It's a very strange feeling when you're going slow. Totally different if you are going fast.
divimon2000
Re: Shipwrecked
Thanks for posting the story. I think changing the plan is fine; I do it all the time and to me thats what boating is about, but def know the waters or have the GPS/charts.
The boat Im restoring right now (70's Jetflite) must have hit something(s) hard and fast. The bottom had amazing gashes in it (nose, strakes, rear), the transom glass was cracked where it meets the hull and the steering wheel mount was smashed in! I just barely figured out the magnitude of this disaster since I've been working on one section at a time. I bet the engine was sheared right off.
It came from the Granite filled lakes of NH.
H20Rat
Re: Shipwrecked
ran over a 4x8 sheet of plywood at speed once, no damage as I was in the jet boat, but I'd have to imagine a sheet of 4x8 3/4" thick floating just below the surface might be enough to knock off an outdrive, or at least damage it. (don't try to use an outdrive as a table saw!). Turns out there was a construction crew working on a new bridge and they were tossing the sheets down to a barge below. As you can guess, a 4x8 sheet of plywood doesn't exactly fall straight down, so maybe half were actually landing on the barge.
bassman284
Re: Shipwrecked
A few years ago I was humming along in the local reservoir doing about 35 when all of a sudden the starboard side of the boat liftedup. Just a few inches but enough to get the hair on my arms standing up. Best guess was a submerged power pole. The lake was glass smooth and nothing showed at the surface. When I started breathing again I went back to look but couldn't find anything.
floattest
Re: Shipwrecked
It was asked what the damage looked like. I attached a pic. I haven't got it fixed yet. I have a few questions about that, but it's not for this thread. The other pic is out the back of the boat in the area we were crabbing. It really was a cool day. Now when I see a clear day, low wind and 28 degrees I think boating! :) haha. If my boat didn't have a hole in it I would have pulled a lot more dungees, dangit.
GLENN M
Re: Shipwrecked
i was piloting a 36ft west coast fishing boat geared for shrimping out under second narrows bridge van b.c about 1 ft chop and sun coming up behind us refecting off waves.all of a sudden there was a heck of a bang i mean i thought i hit a rock,i looked down forward compartment for water rushing in nothing i ran out back to see what i hit nothing i swear a good minute goes by and whoosh up comes this 20 ft 1.5ft wide log i must have drove it down 30 or more feet i dont no what scared me more hitting it or it jumping out of the water,those boats are tough and thick hardly a scratch
float2
Re: Shipwrecked
What a story floattest. A fellow OMC stringer owner myself ie: 225 (sbc). I could pm you some maintenance stories myself, hahahaha.
