beason
- Joined
- Mar 15, 2011
- 338
I have a 99 sea ray 180 with the merc 3.0l and alpha outdrive. I am pretty sure it is the gen 2.
I have a busted shift bellows, and will be replacing this. I will replace all the other bellows, along with the gimbal bearing, and water impeller. The boat is 12 years old and i dont know when they were done before.
Here is my shopping list so far. I would like some advice on where to purchase the items as cost effectively as possible, and to make sure i didn't leave anything out. I have a friend that used to do boat mechanical work, and he has all the tools needed. I just need to get the parts.
Shopping list:
shift cable kit (this comes with the bellows)
exhaust bellows
drive shaft bellows
bellows cement
gimbal bearing
shift cable seal
water impeller
what do i need to get as MERC parts, and what can i get away with aftermarket?
Will i have to drain the lower to replace the impeller?
If so i will need oil, and the oil pump kit to fill it.
If anyone has links to the parts i need that would help tremendously.
I also plan to change the prop from a 21p (speed prop) to a 19p prop. I found this one, that looks to come with everything needed. Any caution on this brand?
http://boatpropellers.iboats.com/Me..._992004_Propeller/437/1130/?*******=626107417
What does the DIA of the prop do for me? Im not sure what size i have now.
I see this one which is slightly larger in DIA.
http://boatpropellers.iboats.com/Me...-153-19_Propeller/437/9546/?*******=510407331
we use the boat primarily for cruising the lake, and tubing, but i got some wake boards for next year.
Shopping list:
exhaust bellows
drive shaft bellows
bellows cement
gimbal bearing
shift cable seal
water impeller
