Shore power hookup
mnmlexus
I'm looking to add shorepower to my boat this year adn am looking for some suggetions.
I was going to add 1 outlet in the cuddy and set up a charger for the battery. Mostly to watch movies or leave some lights on when sleeping overnight.
Is there anything else i should consider adding while i'm at it?
2000 Rinker 232 Captiva.
arks
Re: Shore power hookup
Well, your shorepower inlet should be a weatherproof twist-lock style and mounted on the side of the boat that is closest to the power source (if you use a wet slip).
Think about adding a small AC panel to control your 120V circuits.
You might consider adding a weatherproof outlet in the cockpit. It could come in handy.
The charger should be hard-wired into a junction box because an outlet should never be installed in the bilge.
Just my 2c...
eastern27
Just my 2c...
Don't think about an AC panel, put one in. I don't think your insurance company would look kindly on a boat with AC outlets in the cabin and no circuit protection. If your in saltwater you will want to consider a galvanic isolator.
mnmlexus
A/C panel for sure. Thanks for the input guys.
Love iboats!
