Short shaft on a long transom
duckhunter55
I was wondering if it is possible to put a short shaft motor on a long transom boat. I was thinking of using a mini jack plate and just putting it so the vent plate is even with bottom of boat. Is this practical and do you see any problems arising? Thanks
tashasdaddy
Re: Short shaft on a long transom
motor getting swamped, when stopping quickly, or other boats wake. will have to use a backset jackplate, to get clearance between transon and front of motor. it is much easier, to use a long shaft on a short shaft transom, than what you are trying. you have to be able to tilt the motor.
Dhadley
Actually it's done all the time. Some boat / motor combos work real well like that. Some hulls are intended to work with a shorter motor, just depends on hull design mainly.
What exactly are you working with? It's impossible to answer without knowing.
reelfishin
You are only talking 5 inches in most cases, a common jack plate may well be all that you need. (Most 25" motors have enough mounting positions to raise the motor up high enough to handle a 20" transom).
Just make sure the transom you are bolting the jack plate to is sound and not rotted.
duckhunter55
The motor would be short shaft 25hp chrysler on a long transom jon boat. thanks for advice guys
