Re: Short shaft on long transom
The 15" is called the transom height; and it is the distance from the inside top of the motor bracket to the top of the propeller. So if your transom were 15", streamline water would flow from under your boat to all the blades of your propeller. <br />If you install the 15" on a 20" transom, and if the waterline is greater than 5"; the boat will still operate OK, but will not be as efficient as possible. And the exhaust noise may be louder than you like. Also you may get vibration from the prop.<br />But, try it; it may work OK.<br />Most important: check the water flow as soon as you start the motor. If no flow, shut her down.
