I currently have an 89 Force 50hp long shaft on a 20" transum but the cav plate is at least 2" below the bottom of the hull and the boat performs horribly (snail slow hole shot and 23mph WOT on 15' fiberglass bass boat). I found a real deal on an evinrude short shaft that seems to line up even with the bottom of the hull (maybe 1/2 inch above. Will this motor work on my boat or is there a way to lower the transum mount? Is the major problem water intake? Thanks.
