Silvertip said:Load test at your local auto store. But since it's the second new battery (in how long) I doubt it's the problem. With the Master switch off, my money is on the regulator/rectifier. Which brings up a question. When you mention "Master Switch" do you mean a master switch on the console, or a Battery Disconnect switch? If you mean a Master Switch on the console, that should kill all accessories except anything wired directly to the battery -- such as a bilge pump and the large battery cables. If that's the case, I'll double my wager on the regulator/rectifier. Just curious, but did you ever disconnect the battery cables (accidentally or on purpose) when the engine was running?
I/O said:.As fast as this beast runs down there should be an arc when breaking the battery conn. at the battery!
