Hey all,
I have an older 14' Aluminum, transom measures 19.75" Did a bit of reasearch before purchasing a 25hp 77' Johnson sea-horse short shaft (model 25R77H). I got the impression that as long as the cavitation plate was within 2" (above or below) the bottom of the hull everything was fine.
When the motor is on the boat, the cavitation plate is about 1.75" above the bottom of my transom. When I took the boat out this afternoon it seemed like the prop was cavitating past 1/2 throttle. I played with the tilt of the motor but it didn't seem to make a huge difference.
Based on the information I have provided do I need a long shaft? Do you think I would be better off financially to purchase a conversion kit (if available), or some sort of bracket (if it exists)? Any suggestions whatsoever would be most appreciated
Thanks in advance,
Colin
Thanks in advance,
Colin
