Short to Long Shaft
NUTZ
Howdy All, I have a 1968 Evinrude Bid Twin 40hp short shaft motor that I would like to convert to a long shaft. I figure all I need is the longer drive shaft, shift linkage, water tube and the extension plate for the lower unit.
Is there anything else that I am forgetting?
Thanksd:)
WillyBWright
Re: Short to Long Shaft
The hardware, especially the long bolt for the back. A skirt extension if ya wanna keep it purty.
F_R
There is an extension tube that takes up the space normally filled by the water pump, with two o-rings around it. It won't run with the hood on if you leave that out. Also, it takes two water tubes, not one. You'll need 6 more stainless steel bolts for the gearcase to extension also.
You are supposed to replace the reverse lock springs with stronger ones too.
NUTZ
I just picked up everything I need for the conversion off Ebay for $59 bucks.
Thanks for the quick replies
samo_ott
"There is an extension tube that takes up the space normally filled by the water pump, with two o-rings around it. It won't run with the hood on if you leave that out"
I've heard that before, what does that little extension do and why will it not run with the hood on if not there? thx...
