NJCoastFlyFish
- Joined
- May 22, 2005
- 92
I am going to take a look at this engine, it is a 1986 evinrude 70hp. Motor has no problems EXCEPT cracked emulsion tubes (tubes that pick the gas up to the carbs) that cause the engine to run ruff, it's compression it also around 80 on all cylinders. Would these bad carbs somehow cause unusaly strain on the engine, or is it not that big of a deal?<br /><br />I don't know what to make of this, if I put new carbs on will the engines compression go back to normal (I think around 100)
