Should I buy?
ml8163
I have the opportunity to buy what I believe is a 1990 21' Cuddy Cabin made by Sunbird for $500. I haven't seen the engine yet, so I don't know the size, but it is an OMC engine. Also, the engine needs to be replaced as there is a crack in the block. I'm told that the interior is in good shape with no soft spots in the floor. I need to check these facts for myself.
My question is, assuming all of these facts are true. Is this boat worth the $500 to buy and replace the engine?
I've heard to stay away from OMC since they are no longer around, but since I will be replacing the engine does that matter?
sw33ttooth
Re: Should I buy?
well if you replace with merc outdrive and crate motor your talking 10-15 thousand dollors depending on labor about $6000.00 for motor new and $2000.00- $2400.00 for alpha outdrive weather you get refebished or band new. personally i'd stay away if you bought it for $500. chances are you can sell off parts and make money then chop the hull and deliever to local land fill. now you maybe be able to find a used merc. motor that runs good with a few hours and an ungly outdrive all depend on your luck and wallet.
emoney
Re: Should I buy?
Are you getting a trailer too? If the hull really is solid and that means the deck & stringers are not rotted, and you have a serviceable trailer, the $500.00 is cheap enough. As for the powerplant, I'd scour other listings and find a donor boat. You can usually find something that's got a damaged or rotted hull but a working eninge/outdrive and swap. As for the rest, just cut it up with a sawzall or chainsaw and haul it off in pieces. Probably best to take some pics and post them up of the deck, etc. to get some real advice.
ml8163
Re: Should I buy?
Yes, the trailer is included and appears to be in good shape.
Bob_VT
Re: Should I buy?
Sunbirds had POOR (putting it mildly) construction in the hulls. :(
If you want buy and part it all out.
ml8163
Re: Should I buy?
Thanks for everyone's input. I hope to go over this evening and look at the boat in detail. I'll let you know what I decide.
