Should I fine tune prop to get max rpm?
chaparral442
Prop- 14 x 21 Solas SST 3 blade
Boat- 2006 190 SSi Chaparral
engine- 4.3l Carb Mercruiser
RPM WOT- 4500
Is it worth my effort to have prop tuned to give me the extra 300 RPM"s to get to the top of the power curve?(4800rpm)
What would I benefit?
steelespike
Re: Should I fine tune prop to get max rpm?
Not an expert but::
I guess it would depend in the cost.
I have seen performance improve by removing a little cup.
It could improve performance some besides raising the rpm.
Your actual improvement would depend on your present performance.
What is the speed at 4,500?How is the hole shot?
The experts may be along with some more specific suggestions.
180shabah
You are currently running inside Merc's WOT spec, lower end of, but perfectly acceptable. You are not risking any long term damage, etc.
If you are happy with your current performance - leave it as is, and enjoy the summer.
If there are things you are looking to improve - a different prop is a great way to do it. If you like the characteristics of the SST, but would like a little more acceleration - drop 2" and just keep an eye on the tach if you run WOT.
If it were mine, I would probably go with a 19" Solas Amita4 for pulling, low speed control and heavy load days. Keep your current stainless prop for light loads in familiar water.
chaparral442
Hole shot is good, speed runs about 45 mph gps Local prop guy quoted about 100 bucks to tune the prop
RPM WOT- 4500
Ayuh,... It'll only be Fine Tuned til the load, or conditions change...
180shabah
$100 will buy you a new aluminum prop and provide you with something that tuning the old one won't...
a spare
chaparral442
I already have a spare aluminum prop-
180shabah
If you already have a spare and the shop has a good reputation - go for it...
