Should I have the hull painted?
5thFish
Hi All,
I have a SeaPro 238WA with an all fiberglass hull. It's usually trailered, but we keep it in a slip during the summer. It's a new boat with nothing but the original factory gel coat on the hull. This past summer we had a good amount of fouling and the gel coat hull took a bit of abuse with all of the bottom scrubbing. It's probably okay, I'm just a bit paranoid.
Before I put it in the water again next summer, I'm wondering if I should have the hull painted? Is there a protective, antifouling paint that would protect the hull in a preventative maintenance way? Is it worth doing this? Or will I be okay with the existing gel coat for a couple seasons more?
kaferhaus
Re: Should I have the hull painted?
Any boat that gets left in the water for months at a time needs one of two things, Pull it out every month and scrub the bottom, or have a good coat of anti fouling paint applied below the water line.
I personally hate painting boats. However I have a sailboat that stays in the water year round because of the draft.... even that boat I get in the slip every month or so at low tide and scrub the bottom with a brush. Ever try breathing through a short garden hose? LOL gets tiring after awhile.
Anyway even with that effort I have to have the boat hauled and re-coated every few years. This process is not inexpensive....
IF I ever buy another sailboat it will be a "trailer sailor".... the cost of hauling and painting averages out to $450 a year.... and We only use that boat 6-7 times a year.... add insurance and other maintenance costs and we're likely paying close to $200 a pop....
I'd sell it but with the economy as it is....
tashasdaddy
really not enough info, where, fresh or salt water? how often do you use it?
5thFish
During the summer, we're out a couple times per week. During the winter months about once a month. Salt water, San Diego.
The first two weeks the boat was in the water, it accumulated a considerable amount of fouling. 3 to 4 inches of algae around the waterline, engine, and trim tabs and a good coverage of barnacle "spots" under the waterline and some sort of calcifide tube worm crustation. I scrubbed it every two weeks all summer and when the we took it out of the water I spent a day giving it a good cleaning, the tube worms were a big problem. Next summer I plan to hire someone to do the scrubbing, but I wonder if I should protect the hull first.
Gary H NC
Sounds like it really needs a good layer of anti-fouling paint.
If not do not be surprised if the gelcoat starts to blister and get permanent stains.
tashasdaddy
yes, you definately need anti-foul paint.
NSBCraig
Yeah I also think you should bottom paint it.
The only experience I have with bottom painting was on my brothers 41' Velocity.
I used Pettit Vivid black.
It was real easy to do, use one of the thin rollers, looked great.
It took a little more than half gallon.
