I have a 1978 15 ft Tri-hull with a 1960 Johnson 40 HP SS that I put on it. I am not getting the speed I feel this setup should produce at WOT. I was told to raise the engine up but to be careful due to the age of the engine the water intakes are set higher on these engines. I think my engine sits too low for the boat ( attached are pics). It seems if i raise the engine, the engine will be sitting almost at the top of the transom and would put too much strain on the transom.It's only running at about 15 or 20 mph right now. Can anyone tell me by looking at the pics what I should do? Or would a newer year engine be the way to go? This engine does run really good.
Thank you sincerely for your reply's.
