Re: Should water come out idle releif when using muffs?
This Old Boat<br />I flush my motors 10 to 15 minutes after saltwater use. Most wash stations out here have a 15 minute limit. I rigged my flushing hoses up where can flush both motors and wash boat and trailer all at the same time. Main hose goes to a y adapter. one side of Y goes to another Y adapter with shut off valves. This Y I limit water flow with a washer with a small hole. Output from this Y goes to both engines. Other side of first Y goes to my washdown hose. With this set up I hook up both motors and start up then I use hose and wash boat, fishing poles, motors, and trailer. This takes 10 to 12 minutes or a littler longer if it is the last day of our saltwater trip.<br /><br />Most at the wash station hook up first motor and run for 5 minutes, then second motor and run for 5 minutes, then wash the boat and trailer for for 5 minutes. This may be long enough but I can fush better it and not have to hurry so much when there is a line and still not go over my limit.
