Shutter Location
DemersChrisG
Hello People, <br /> I'm a "do it yourselfer" here and I need to Check to see if my Exuast Shutters are ok. Usually, on a I/O Vovlo SternDrive where can the shutter/s be found? Once found, is there anything special that I should look for to check servicability?<br /><br />Thank you for your time, <br /><br /> Chris
Reel Poor
Re: Shutter Location
Someone will need the year, engine size, and type of drive to be able to help you.
DemersChrisG
Its a 1979 Bayliner Victoria (27')<br /><br />It has a Chevy 350 bolted up to a vovlo sterndrive(not sure exactly what model)
Don S
Volvo has NEVER used year as a way of detemining what model of engine and drive you have, and who knows what Bayliner used in a 79 Victoria.<br />So without knowing what drive or engine model you actually have, some had flaps over the exhaust ports on the drive istself. others had the flappers installed in the exhaust bellows.
DemersChrisG
okay then Don. I will give it a look. Thanks for the input.<br /><br />-Chris
