Re: Sick of getting pulled off the lake!
Guys.. he says what the motor is at the bottom of the post:<br />"It is a 50 horsepower Evinrude made in 1982" <br />82 50HP Rude....<br />step 1 is to make sure the primer bulb is hard when you try to restart it.<br />step 2 would probably be to pull a plug when the problem occurs and check its condition.. is it wet??? if you have a stuck float or similiar, you might even be flooding it. while you have the plug out, test for spark by holding the plug thread hard against the block and turning the engine over.. (do this with the plug lead on.
<br /><br />corse if the engine isn't even turning over then you have to check the<br />battery/key-switch/soleniod/starter system.<br /><br />tell us more about the problem and we will see what we can do...<br /><br />Once thing I found that helped my old evinrude, (alot older then yours) was to keep a squirt bottle full of premix handy, then when I had the problem, I'd pull the cover and squirt a shot down the carb throats.. and it would then fire first shot.<br /><br />good luck,<br /><br />rgds<br /><br />frank
