Side control handle removal
castaic piper
Re: Side control handle removal
Remove the button that controls the throttle only when shifting. Next pull the shifter in full reverse and slide in 1/8" allen wrench at the base of the handle and remove the set screw. Now pull out the control handle.
In this schamatic Remove 33,48. when in full reverse #57
http://www.boats.net/parts/search/B...OTE CONTROL - CONCEALED SIDE MOUNT/parts.html
Now to fix the next problem in another post.
muc
"Retired" Association of Marine Technicians...
Sometimes you need to disconnect the throttle cable at the carb so the handle can rotate far enough to get to the set screw.
