I have a 1979 Century with a repower 1997 5.7 carb and thunderbolt 4 ignition MR drive. I added a sierra audible alarm that wires to oil pressure and water temperature. I used a regular 350 oil pressure sending unit as the second pressure sensor, as the first is wired to dash oil pressure guage.
the problem is that when I turn the key on, before start, I know the alarm should go off, before the engine builds pressure. It does not. if I ground out the lead from the standard oil pressure sender wired to the alarm with key on, alarm sounds.
question: should the regular sender work on the alarm, or do I need a special sender?
help appreciated!
help appreciated!
