Sierra pump ok on my Vovlo 5.7 ?
HawaiianHooker
Hello,
Does anyone know if I can use this Sierra Fuel pump (18-7330) on my Volvo Penta 5.7 Gsi?
Thanks!
Fun Times
Hi there, looking back for your full engine model number I see you have a 5.7 GSI-PWTR.
The sierra pump in question (18-7330) will work as an aftermarket replacement for your OEM Volvo part number 3857650.
Fuel Pump 18-7330 Replaces OMC / Volvo part number: 3857650
Also looking over some of your past history, you posted a photo of the fuel pump while asking about a 1/2 inch hoes going to your exhaust riser. Is that the fuel pump your looking to replace? If so, just so you're aware, that is the high pressure fuel pump, you also have a low pressure pump mounted by the fuel filter. Here the links for references, http://forums.iboats.com/forum/engi...8855-what-is-this-and-where-does-this-hose-go and http://forums.iboats.com/forum/engi...88-mysterious-elbow-on-my-port-riser?t=564678
If the link works correctly, here is your fuel system, (items 20 and 43) http://www.volvopentastore.com/Fuel...on_id.518260341--store_id.366--view_id.775947
And here should be your parts catalog for you if ever needed, http://www.volvopentastore.com/Mari...on_id.518260341--store_id.366--view_id.765176
iboats offers the same fuel pump if you're interested...Plus if you call them they may price match west marine also be sure to mention the FORUM5 promo code seen below.:) Hope this helps, good luck.:) http://www.iboats.com/Electric-Fuel...1538666--session_id.986631935--view_id.172177
