Re: Signs of a bad Gimbal bearing?
Without removing the outdrive the signs you will get are the ones you will hear.Then it is waaaay too late.With the drive off you put your fingers on the bearing and see if it moves smoothly.If you are not sure if it is bad and cant get the drive off ,then pump a bunch of grease in it and dont use the rig much until you can check the right way.Charlie
