Silly Question
Medic4040
What exactly is porpoising???? I've seen it a couple times in diffrent threads and am not quite sure what it means, how do I know if my boat is doing it :confused: and if so what can I do to fix it :cool:???? Like I said silly question
but thanks
JB
Re: Silly Question
Porpoising is when your engine is trying to raise the bow of the boat higher than it can keep it. The result is that the bow bounces up and down, porpoise-like.
It is usually caused by too much trim-out of the engine. The fix is to reduce the angle of trim-out until the boat settles down.
Medic4040
Re: Silly Question
ok not a problem with my boat when I run it. Thanks for the help.
Silvertip
Re: Silly Question
The opposite of porpoisiing is "plowing". This is when the bow of the boat does not ride high enough when on plane. It therefore plows its way through the water almost like it does before it gets on plane rather than skimmiing over or slightly off the surface of the water. That problem results when there is too much weight in the bow of the boat or the engine is trimmed in too far.
Medic4040
Re: Silly Question
figured there had to be an opposite to porpoising, thanks for the info.
