I know this is a retarded question, but I'm unsure of the answer nonetheless. The PO of my boat wired in a fuse box and all of the + connections run through it. Simple enough. The grounds all seem to be wired to a negative battery connector like it was originally connected to the negative battery post. Is that normal or should it be grounded to the aluminum hull?
I don't see a spot on the hull where a bolt was clearly placed for grounding. I'm thinking it was connected to the negative battery post. Is that okay? Do I need to run all of my grounds all the way back to the negative battery post or just the positive leads when wiring more accessories?
Thanks for helping, I'm hitting the lake tomorrow AM and I'm trying to test the fish finder (pretty old, I'm not expecting much) and the trolling motor as they came with the boat.
Thanks for your help, I'm having a great time with this.
