- Joined
- Mar 8, 2009
- 42,535
Have a Woods Batwing finish mower model 9204RD-2
Issue: L/R wings will not move enough to lock into transport latches without manual help
It use to be only the left wouldn't latch without help but now it's both.
Noticed today that the piston on the ring has not retracted and has at least 1 inch of the rod showing. The cylinder on the left has maybe 3/8 inch showing. The rear wing latches every time without issue
Got to think what could cause this. I'm assuming one side is hydraulic fluid and the other side is just air. There are no leaks on cylinders. What might be the cause? The nut is backing off on inner piston or something else
