DunbarLtd
- Joined
- Nov 8, 2016
- 357
I am replacing the hubs on my single axle trailer that i use to pull a 17ft fiberglass boat. I noticed last time out the starboard side rim had black grease flung all around the inside. So when i had the time i took off the rim and hub and removed the seal and bearings and I noticed the inside bearing was rusted and ready to explode. It was mangled pretty good. I only have a 20 minute ride to the lake but still i feel lucky i didnt get stranded.
So i do some more inspecting and after i removed the hub on the port side (Which did not leak at all) i realized why the starboard side hub had been leaking. There appears to be whats called a "wear sleeve"(after much googling) on the spindle where the grease seal rides.
Well on the starboard side, where the leak was, this sleeve is missing. I took a picture to help people understand what part I am referring to. You can see the O-ring on there as well.
The grease seal it takes is a TCM 13194 seal. ID = 1.37" OD = 1.98"
The bearing used is a L44649 I believe the size is 1 /16" spindle but i could be wrong. I need to go buy a caliper to make sure. But I do know those were the old bearing numbers. Just dont know the spindle size.
My problem is I absolutely have no idea where to find the "wear sleeve". Nothing is popping up on google. Ive called tractor supply houses. Nobody knows what the heck i mean. Maybe there is another word for it and I just dont know.
Hopefully someone is familiar with this part and may recognize it. Thanks for any help!
