If you do a google search, spelling out V/P duo prop vs single prop, you'll find several old side by side comparison videos made by V/P when duos were 1st introduced. Both boats are identical except for the drives. I realize these are old videos , but I would think most of the characteristics would be similar in later model drives.
We have an old, heavy, 23ft Chris Craft Lancer. About 1 1/2 yrs ago we swapped out the single prop AQ280 lower to a duo prop version. We found it is more responsive, easier to dock and has more control, it comes out of the hole a lot harder. RPMs are slightly less when going the same speed as b4 and slightly more efficient in the low to mid rpms. The old drive had a slight whine when in gear and the duo is silent. Top end seems to be about the same, maybe a mile an hour or two faster. I must say I am not familiar with the newer drives. Hope this helps. I never comment on money. I'll only say, if your deciding because of efficiency, youll never recover the money
